Dexter e-z lube axles
gamma3116
Hello I would like to know if any one out there has the Dexter E-Z lube axles and have grease your wheel bearing by using this method? I just found out after 5 years of owning this 5th wheel that I can lube the wheel bearing from the axle were there is a grease zerk fitting installed. I just when on you tube and watch as they grease the bearing. I was wonding if the inner wheel seal will stop the grease from going into the brake drum and onto the brake shoe's. I would love to hear from any one that has grease their wheel bearing using the Dexter E-Z lube system to let me know if the seal kept the grease from going through to the drums. Thank You for any replys Jeff
9 REPLIES 9
Huntindog
gamma3116 wrote:
Well after reading all the post I pick up my phone and made an appointment to have them remove the drums and repack the bearing. Thank You all for your responses. Jeff
Be sure they actually do it that way. Often the shop will just use the zerk, and charge for the repack. I suggest watching them.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
fj12ryder
Five years is a decent amount of time between bearing services. Now you'll be good for another 5 years. I did mine after 7 years, all was good, so I'll do it again in a few years.
Howard and Peggy
"Don't Panic"
gamma3116
drsteve
Used carefully, they can work as advertised. Do it wrong, and you'll end up with a mess. A lot of people like to check the condition of the brakes and bearings anyway, and don't trust the cheap seals used by the manufacturers, so they just repack by hand.
I am in that school myself.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
BarneyS
Moved to Tech Issues forum from DIY.
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
azrving
Read the posts but I would hand pack them and replace the seals after a very close bearing inspection. If they were on a smaller axle without brakes grease all you want.
ScottG
Discussed many, many times.
Those that have a lot of years with them, avoid them as they are as likely to put grease on the brakes as the bearings.
BB_TX
azdryheat
Already being discussed HERE
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
