Disk brake actuators...which one?
path1
If you purchased an actuator for disk brakes what did you finally end up with?
I would like to mount mine on the a-frame of trailer, so weather plays a role.
I would like the manufacture to have been in business for sometime.
Most of all a dependable unit.
Thanks
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
6 REPLIES 6
C_Schomer
I used the Carlisle 1600 psi actuator cuz the physical size was better for where I mounted it and I wanted the most psi. It's weatherproof and I've seen them on really old trailers so they must hold up all right. I'm not sure if the Titan is 1600 psi. Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
dons2346
Titan is the only one I would consider
kirbybear
Have had 2 BrakeRites/Titan. Currently on discs for 8 years.
RJsfishin
Buy it from E trailer, they'll advise. Attwood is always good
Wouldn't you think any surge brake actuator is weather resistant ?
Or maybey you talking a different actuator ??
I bought a surge disc brake actuator off ebay, worked great. Don't know the name.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Thanks
I here that the Titan Brake Right is weather proof and made for boat trailers... ..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
midnightsadie
on my boat trailers its part of the hitch , mine are 2in ball,hitch.
