โJun-17-2013 01:38 PM
โNov-11-2016 04:41 PM
jrichardparker wrote:Yes, and you should hear a klunk when it opens.
... should I feel solenoid opening and closing when voltage is applied?
Reese Dual Cam Straight Line HP Sway Control
โNov-11-2016 08:50 AM
โJun-28-2013 06:26 PM
โJun-27-2013 08:40 PM
โJun-22-2013 11:18 AM
โJun-20-2013 07:23 AM
โJun-20-2013 05:02 AM
โJun-19-2013 07:34 PM
โJun-19-2013 06:50 PM
โJun-19-2013 06:32 PM
Units that have integrated igniter do not have a thermocouple. The igniter senses the flame thru the electrode and communicates with the lower main control. The integrated igniter used on certain Dometic model refrigerators operates on 12 volt DC thru the control board. On gas operation the igniter senses the resistance through the flame between the electrode and burner. When there is no flame at the burner, the resistance is high and the igniter begins sparking to light the burner. As soon as the flame is lit, the resistance between the electrode and burner drops and the igniter stops sparking. The resistance is monitored by the igniter, and, if for any reason the flame goes out, the igniter begins sparking until the burner is lit.
โJun-19-2013 05:55 PM
โJun-19-2013 01:44 PM
96Bounder30E wrote:
I guarantee you have a thermocouple.......I have the exact same fridge that you do.....
Here is a representation from another thread.......
โJun-19-2013 12:49 PM
โJun-19-2013 11:11 AM
