โJun-04-2015 04:56 PM
โFeb-07-2016 11:19 AM
bbaker2001 wrote:
my dometic will get to about 38-41. when using refrig it creeps up to 43.
I was looking at manual and it says
In AUTO mode operation, the temperature is controlled by
a single temperature setting.
B. MANUAL MODE
When operating in the MANUAL mode, the AUTO mode
indicator lamp (A) will be off, and the refrigerator will run
continuously on the energy source selected by the control
system.
I do not have a manual option. only auto, and gas. when on gas I think it to would be controlled by the auto temp of about 40.
so if I want colder I can try the dino thermistor.
also when on gas it does not always re ignite and goes to check. is it difficult to change the igniter unit out.
โFeb-07-2016 08:18 AM
โJun-05-2015 09:13 AM
โJun-04-2015 07:25 PM
dougrainer wrote:
Taking the Thermister and just pulling it OFF the fins will allow the refer to run all the time. YOUR problem is, you DO HAVE a problem if the refer will not get colder than 45 degrees. You think the slider is a joke when in reality, your refer has a problem that needs professionally checked out, to find out why it is operating 10 degrees hotter than normal. Doug
โJun-04-2015 05:16 PM
โJun-04-2015 04:59 PM
