Jun-04-2018 02:33 PM
Jun-05-2018 05:01 AM
Jun-04-2018 05:56 PM
enblethen wrote:
If the hertz does not drop to right at 60, then it is set too high or the regulator is failing.
Start with cheap items first! I had to replace my regulator. Got an after market one. Flight systems
Jun-04-2018 04:42 PM
Bud
USAF Retired
Pace Arrow
Jun-04-2018 03:34 PM
enblethen wrote:
I would start by checking all the connections. Inspect, disconnect and re-terminate all the wiring in 120 volt distribution panel and transfer switch. Pay special attention to the neutrals in the back portion of the distribution center. Get some electrical de-oxidation grease. Coat the bare conductors prior to terminating. Look for melted insulation and burnt conductors
Genset is running a little too fast which is causing the higher then normal frequency.
Jun-04-2018 03:15 PM
Bud
USAF Retired
Pace Arrow
