โOct-31-2015 07:30 AM
โOct-31-2015 08:55 AM
โOct-31-2015 08:24 AM
โOct-31-2015 08:15 AM
โOct-31-2015 08:00 AM
The reset procedure is as follows:
a. Turn the ON/OFF switch to ON. The display light with
data should come on. If the light and data are not there,
see Section B2 Cable Assembly.
b. Depress mode to activate display light.
c. Depress the bottom two buttons (up & down) together.
d. While still holding the two buttons add the third from the
bottom (mode) , hold all three for a few seconds.
e. Release the third (mode) button.
f. Release the bottom two (up & down) together.
g. Depress the mode button. The display light should be
off. If not, repeat steps 2 through 6.
The control should return to the default setting of 68oF for
heating mode and 72oF for cooling mode.
โOct-31-2015 07:42 AM
โOct-31-2015 07:36 AM
