Got a new horse trailer with LQ - has this fridge in it. Picked it up and it worked fine when I was at dealer. Drove 3 hours now no lights at all will come on, won't cool in AC or propane.
Checked 12V and there is 12V and 120V working fine. Checked continuity of all fuses on circuit board and main board of trailer. All fine.
I am completely stumped what could be wrong... Seems all the power and fuses are working fine.
Did you check on the incoming terminals for 12 volts DC? Fuse in 12 volt DC distribution panel could be bad. Normally located next to 120 volt AC circuit breakers behind metal plate held in place with thumb screw.
I pulled upper panel and everything is secure. Is there a way to check if that's getting power? On lower circuit board all fuses have continuity (3A & 5A). Can't find any loose plugs at all.
Could the circuit board have gone bad even though it's brand new?
