โOct-25-2015 08:11 AM
โOct-26-2015 08:24 AM
Old-Biscuit wrote:
I use one of these.......fill it with distilled water, insert it into battery cell, push down and water flows/stops when level reaches bottom of opening.
Easy..simple
โOct-26-2015 06:55 AM
โOct-25-2015 07:26 PM
โOct-25-2015 03:05 PM
Old-Biscuit wrote:That's pretty neat. I'll have to look this up.
Easy..simple
โOct-25-2015 02:08 PM
MEXICOWANDERER wrote:
The CORRECT LEVEL is that which is low enough to prevent purging at max charging and temperature. It is pre-determined by the manufacturer according to cell dimension and plate percentage fill. Start with a level 1/8" above the plates then check it again after max charge rate charging. If it did not rise a lot add a bit more water. Simple enough.
โOct-25-2015 02:01 PM
โOct-25-2015 01:10 PM
Old-Biscuit wrote:Yup, putting that on the "immediate wish list". They work great.
Easy..simple
โOct-25-2015 01:04 PM
โOct-25-2015 12:55 PM
โOct-25-2015 09:03 AM
โOct-25-2015 08:43 AM
โOct-25-2015 08:25 AM
โOct-25-2015 08:18 AM
