โDec-30-2020 07:25 AM
โFeb-07-2021 10:51 PM
sdtravis wrote:AllegroD wrote:
Under warranty!
If only service appointments weren't months out!
โFeb-07-2021 03:28 PM
โJan-25-2021 12:04 PM
AllegroD wrote:
Under warranty!
โJan-12-2021 05:18 PM
โJan-12-2021 12:42 PM
โJan-06-2021 12:47 PM
GDS-3950BH wrote:Retired JSO wrote:
The Forest River site has a Dynamax Rep member that responds to questions about his products.
The Forest River site also has lots of posts/threads about that DMR-702 model fridge being garbage in a lot of cases. Its the first model that Dometic had the entire fridge outsourced to China and then slapped their name on it. They call it the Renaissance Series, perhaps the Junk series would be more appropriate? Dometic today is not the Dometic of 10 years ago. They took lessons from from LCI.
โJan-02-2021 06:56 AM
โJan-01-2021 07:57 AM
sdtravis wrote:Refers consume much less propane, which requires much less gas flow, which *may* be an issue with the regulator. You might try the stove with just a trickle.
@2oldman and @2112: Agree, regulators fail but I wouldn't assume they'd fail so intermittently. I get full pressure on the stove at all times.
โDec-31-2020 12:40 PM
sdtravis wrote:
@Old-Biscuit: Spark electrode is definitely suspect if in fact it returns a "hey a flame is present" to the control board. The error documentation on this leaves a lot to be desired, so based on my assumption those errors listed 1-3 aren't what I'm experiencing given both LP + temp flash (variably based on the setting, versus constant to the error). How would I know if that electrode is bad? A bad gap might also be a culprit too but would need to check the spec on that.
โDec-31-2020 11:55 AM
โDec-31-2020 11:38 AM
2oldman wrote:
I am really hoping this isn't a drive-by post.
โDec-31-2020 11:06 AM
โDec-31-2020 06:35 AM
โDec-31-2020 01:49 AM
Old-Biscuit wrote:
The error code is always the same -- two blinking lights,
One is LP
*Gas ignition failed. The gas flame has not been ignited after 45 seconds.
Other -- Temp Setting 1-3
1) *Disconnected gas valve or hardware fault in the gas operation system. (Check the Wire Connections ON Gas Valve and ground connection J1 Position on Circuit Board)
(Check the Spark Electrode wire connection/ceramic insulator for cracks and electrode position/gap over burner)
2) *A faulty temperature sensor device or a fault in the associated electronic circuitry has occurred. (that would be Thermistor connection or the circuit --- J3 Position on Circuit Board)
3) *DC voltage is out of range (drops below/exceeds the limit values approx. 8-18V DC). Very Wide Range on DC Voltage
Suspect #1
Spark Electrode is DUAL Function....provides High Voltage Spark for Ignition AND Return path for Flam Proving Signal (Current generated by flame ionization ---circuit board senses this current/keeps DC on gas valve. No signal/DC to gas valve dropped/error code triggered
Current is only a few milliamps so doesn't take much to stop it/go to ground
Installation & Operating Manual
