Probably the power module board (aka:control board)... My brand new 2019 Rockwood has the same Dometic 2652 fridge. I didn't have the same exact issue as you however. Mine would run fine on gas or 120v, but once it cycled, it would SHUT DOWN and not turn back on and the "check" light would come on..
But, the catch was, and took me some troubleshooting to figure out, it only did this while plugged into shore power... If it was running on just battery and gas, it would cycle just fine.. I even unplugged the 120v plug to the fridge, and it would still not start on gas if plugged into shore power...
I was just about to take it back to the dealer and I figured that out and then searched around and found that this was likely the power module...
Found it on Amazon for under $100 and ordered it.. It came in two days (Prime) and I installed it in about an hour or so. Tight quarters, and little tiny wires, but just matched them up to the original one and it was a perfect match and BINGO! Fridge cycles perfect while plugged into shore power on gas or 120v and also while just on 12v and gas..
🙂Sure, it would have been covered by the warranty.. But, I would have had to take the trailer to the dealer. They would have had to troubleshoot themselves, then order the same thing I just did and install. Pick it up, park it back at my house.... Ughh... Probably would have taken a week or longer... In the end, not worth the $100 and some and hour or so of my time..
Plus, I get the satisfaction of fixing yet another thing on my own and it worked out great.
Here is the link to what I got on Amazon.
https://smile.amazon.com/gp/product/B00BURPLEW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1Good luck! Mitch
