โAug-26-2020 08:25 AM
โSep-11-2020 09:31 AM
โSep-01-2020 08:24 AM
Gkaiser wrote:
Replaced Eyebrow Board. Fridge now works on electric, and the temp this morning was 30deg. so now it's over cooling. just needs the thermistor adjusted down to dial in a good temp.
So all problems fixed. seems like it was just the power switch all along, but now it has all new circuitry top to bottom. ~$180 total on amazon.
Model is a DM2852RBX
โSep-01-2020 06:59 AM
โAug-29-2020 12:43 PM
Gkaiser wrote:
Doug,
Left running overnight with newly installed thermister. Freezer is at 10ยฐ fridge was cold below 50ยฐ but had to get to work, didn't have time to wait for the thermometer to fully read. But it is definitely colder than it was getting before the thermistor install.
SO I believe my only remaining issue is why will it not flip over to electric?
I checked the output voltage at Jumper 7 and 8 (I believe it is)and was not getting 120 but I am getting 120 though the fuse. I still believe I need to replace the upper control board.
If I am not getting voltage to the heating element why hard wire it? you got to start at the source and work your way to the end. if I am getting voltage to it, and its still not cooling well then yes I need an element, but right now I am not getting power to the leads.
โAug-29-2020 10:06 AM
โAug-29-2020 06:35 AM
โAug-28-2020 05:54 PM
โAug-28-2020 05:49 PM
โAug-27-2020 08:16 AM
Gkaiser wrote:
Doug,
โAug-27-2020 06:51 AM
โAug-27-2020 06:03 AM
Gkaiser wrote:
Freezer is cold enough to freeze the milk i put in there to keep it cold.
Replaced thermistor - now retesting.
Also checked voltage at board for heating element and sill getting low voltage with new board.
Could eyebrow board be bad also and not signaling the main board to go electric?
So 2 problems 1 fridge isn't cooling and 2 it only works as gas. Either in gas only or auto mode. It goes to gas.
โAug-26-2020 07:30 PM
โAug-26-2020 04:30 PM
โAug-26-2020 03:32 PM
