โFeb-10-2018 12:31 PM
โFeb-13-2018 11:00 AM
bentSpaceTime wrote:Chris Bryant wrote:
Thanks Doug- darned autocorrect!
The easiest thing to check is, with the refrigerator down to temperature (cold), does the gas thermostat modulate the flame in the middle of the travel, or just right at the very bottom? If it only makes the flame smaller right at the bottom, it's bad. If it is in the middle of the range, we can work with it.
What do you mean by travel?
โFeb-12-2018 04:52 PM
โFeb-12-2018 05:31 AM
โFeb-12-2018 03:43 AM
Because the thermostat is modulating the flame, I doubt it has lost its charge, unless it only modulates at the very bottom of its range.
Have you checked the lip pressure? I would sure start with that.
I'm pretty sure I have several of those v35 thermostats, if I can find them.
How do you check the lip pressure?
โFeb-12-2018 03:42 AM
Does moving the capillary tubes up and down on the fresh food evaporator fins do anything, as far as adjusting the temperature in the cabinet?
โFeb-11-2018 02:59 PM
โFeb-11-2018 02:57 PM
โFeb-11-2018 12:41 PM
โFeb-11-2018 02:42 AM
โFeb-10-2018 04:27 PM
dougrainer wrote:
Yes, I found a few listings for the Gas Tstat. NONE for the electric tstat. So, if the Gas is defective, maybe one of the suppliers still has the gas tstat (pn 62303). Doug
โFeb-10-2018 03:11 PM
Would replacing the thermostat fix the problem, if the bypass flame is too big?
โFeb-10-2018 02:56 PM
โFeb-10-2018 02:55 PM
โFeb-10-2018 02:21 PM
