โMar-08-2015 11:24 AM
โMar-09-2015 02:24 PM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โMar-09-2015 01:36 PM
โMar-09-2015 12:42 PM
Reddog1 wrote:
You do not need a battery in your TC for those to work.
If you disconnect the power cable from your truck to TC, do the lights on the truck work properly?
โMar-09-2015 10:15 AM
Toad: 91 Zuke
โMar-09-2015 09:46 AM
โMar-09-2015 08:43 AM
Toad: 91 Zuke
โMar-08-2015 06:49 PM
โMar-08-2015 06:09 PM
TucsonJim wrote:
"Anywho, I dont have a volt meter on me and dont need the battery this trip so will check it when I get home."
Please don't forget that you need to have a charged battery when you are towing. If your trailer were to become detached from the tow vehicle while on the road, the break away system will not activate the trailer brakes if you do not have adequate voltage on your trailer battery. This could be a very serious problem for both you and others on the highway. Never tow without a fully charged and functional battery in your trailer.
โMar-08-2015 02:35 PM
wnjj wrote:
Sounds like a shorted cell in the battery.
โMar-08-2015 12:48 PM
โMar-08-2015 12:33 PM
Ivylog wrote:
Those detectors are dual purpose and should also be labeled as audio low voltage alarms
โMar-08-2015 11:41 AM
