Mar-29-2014 06:42 PM
Mar-30-2014 03:40 AM
Mar-30-2014 02:50 AM
Mar-30-2014 01:29 AM
Mar-29-2014 08:55 PM
booster wrote:
Check the voltage at the batteries while charging, it should be within .1 volt of what you see at the charger or solar controller output.
Mar-29-2014 08:51 PM
CloudDriver wrote:
One additional thing to test - make a note of the voltage at the chassis and house battery terminals, then start the engine and check the voltage at the chassis and house battery terminals again. The voltage at the chassis battery will rise if the alternator is working. If the voltage of the house batteries doesn't rise to be close to the chassis battery, you aren't charging from the alternator while driving.
Our Class C has a relay that connects the chassis and house batteries together when the ignition is on. In 11 years, I have replaced this relay three times because charging of the house batteries became unreliable.
Mar-29-2014 08:42 PM
Mar-29-2014 08:20 PM
DavisK wrote:
Your charger is not on while you're on the inverter is it? It will drain the batteries trying to charge them.
Mar-29-2014 08:18 PM
Handbasket wrote:
Have you checked both ends of the ground cable for clean & tight?
Mar-29-2014 08:15 PM
Mar-29-2014 07:37 PM
Mar-29-2014 06:56 PM
