Energy efficient residential refer amp draw
Texas_Two_Stepp
Does anyone have information from a reliable source on the amp draw (@ 12v) of an energy efficient residential refers over a 24 hour period under normal operating conditions? (By normal operating conditions I mean full of food, opening and closing 20-30 times a day with an outdoor temp of 85ish.)
2015 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
11 REPLIES 11
DaHose
Say .... that is a GREAT hint about the defroster. I will need to take a look and see if I can do the same with my fridge.
Jose
Gdetrailer
I have a 10cu ft Haier home fridge I put into my TT.. I measured it at 90W running (.75A) with a name plate rating of 1.1A.
As you can see my fridge is drawing slightly less than the name plate rating.
I measured the run time as about 20-25 minutes per hr averaging about 22 minutes per hr. Heat doesn't seem to bother it much from what I have been able to tell. We often overnight while traveling during the summer and the temps at night are often 80F..
Now opening and closing 20-30 times a day and that time will be thrown out the door.. I would expect you will have run times closer to 30-40 minutes per hr when accessing it that often.
Something to consider in your calculations is pretty much all home fridges are "frost free". That means that they will operate a defrost cycle which turns on a heater element in the freezer to melt the frost off the coils.. On my fridge that is about a 250W heating element.
My defrost cycle is ONCE every ten hrs of compressor run time.. For traveling I rigged my defrost timer with a switch to disable the defrost cycle.. I reenable the defrost once I get to my destination with shore power..
Depending on the humidity I can go as long as 6 or 7 days before the fridge starts not work as good as it should without defrosting it.
westend
The yellow sticker is close to actual usage but is usually a bit conservative (allows for users with more access events and higher ambients). When doing the conversions to 12V, take into account the loss of efficiency of the inverter. Not all inverters are the same. Some say the constant denominator should be "10" but the newer inverters are slightly more efficient. Wiring has a role in this and I'd suggest to use the largest possible wire gauges throughout. The possible savings of using smaller wire will be surpassed by usage in short order.
I use a smaller 120V fridge so my numbers won't be applicable to yours. I have a smaller 12V power system too.
'03 F-250 4x4 CC
John___Angela
ScottG wrote:
smkettner wrote:
Don't they all have an energy sticker?
Post what it says in annual kWh and we can convert to daily 12v power.
Yes they do.
You can go to Home Depot's web site (or others) and get all the energy usage specs for a given fridge.
I went on that site and found that if you pay just a bit more and get an Energy Star rated fridge, it will use far less power.
I think that's well worth considering when your running it of your batteries.
Excellent idea. But when calculating what a fridge uses don't look at the current rating on the back or the cord. That is an indicating of the current pull at start up and is mostly irrelevant when figuring out a power budget.
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
ScottG
Yes they do.
time2roll
Texas_Two_Stepp
Thanks for the information. I was figuring around 80 to 100 @ 12v but my information is several years old.
TST tire monitor
3-135w solar panels
Tristar controller
Trimetric monitor
MrWizard
Moderator
Moderator
I agree approx 1.2 kwHrs aka 100 ampHrs
I can explain it to you.
1997 F53 Bounder 36s
John___Angela
So, simple answer to your question, ours uses just around a kilowatt per day. A little more in the summer, a little less in the winter. So lets say around 85 to 95 amp hours per day on a 12 volt system. Mas o menos. ๐Ÿ™‚ Round it out to a 100 and you are probably golden.
Hope that helps.
2oldman
You mean when running on an inverter? It would be ~ 10x the amp draw at 120v.
household refer and inverter2009
Household refer Class A 2009
residential fridge- boondocking 09
Residential refer Class A 2010
Norcold w resi, class a 2014
rk911
a residential fridge uses 120-volts AC, not 12-volts DC. the amp draw should be on a label in your manual or on the fridge. but, an amp is an amp is an amp. if you're using an inverter and the fridge pulls an average of 5-amps per hour (just an example), the inverter will pull 5-amps from the battery cuz that's what the fridge calls for.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
