ENGINE A/C PROBLEM, NOT ALWAYS COOLING
Coachmen63
We have a 2006 Coachmen Aurora Class A motor home with a Ford F53 chassis and a 6.8L V10 engine. We are having intermittent problems with the engine A/C system. We've evacuated the system (3 times), replaced the dryer and expansion valve, but still have a problem. When the expansion valve was replaced this week, the air coming out of the vents was 36-38 degrees when checked by the mechanic. When I picked up the motor home and drove home, the air from the vents was approx. 62 degrees. The pressures are holding so I don't have a leak in the system and the coach only has 16,000 miles on it. I was wondering if we may have a problem with either the vacuum for the door or the door is catching when trying to shut off the heat side of the system. I've been trying to find more detail about the Evans Tempcon system and did find a pdf that show the major system components. Anyone have any suggestions where we go from here? I don't want to keep chasing parts. Thanks for any help you can provide. Service center for this a/c system is a solid 3 hr. drive away.
15 REPLIES 15
j-d
To Doug's point about MAX A/C... Friends have an older, smaller, Class A. The refrigerant charge was low and we corrected that. They were still uncomfortable in the thing and I found that "normal A/C" allowed simply huge amounts of outside air into the coach. Not sure if it was design, install, or component failure but it was like trying to A/C with a window open. They now use the A/C on MAX. There are plenty of other ways to get some outside air into an RV.
rkentzel
Yes it could a Freon problem you could be over charged. Check that out or just keep on replacing parts then when you get done jumping this and that out. Correct charge is critical. Its a fairly easy system to diagnose.
1997 Pursuit class A
ernie1
What was the ambient air temperature,relative humidity and at what speed were you checking the output of the ac? The repair shop had a fan blowing air into your ac condensor, does your engine fan function properly? Under some circumstances, 62 degrees Fahrenheit is all that can be expected.
Coachmen63
I believe they told me 2.5lbs of r134a was put into the system. They have the proper A/C unit to monitor the amount of r134a and system performance. System was only blowing approx. 62 degree cool air yesterday, so it seems either something is not letting the cold gas from the compressor reach the evaporator unit or as mexicowanderer says, the doors/gates are not cycling as they should.
MEXICOWANDERER
Grave doubts your problem has ANYTHING to do with the freon part. A malperforming system can having the freon working overtime and duct inside or outside air directly through the dash vent ports.
dougrainer
1. I seriously doubt the output air was below 40 degrees. That mechanic either has a seriously un calibrated thermometer or he lied to you. You will NOT get below 40 degree air output on a class A motorhome unless the ambient temp was below 60 degrees.
2. Yes, you jump the 2 wires together on the 12 volt tstat freeze control to bypass.
3. The difference between MAX air and just AC on a motorhome is on MAX air the lower outside fresh air intake door is closed to allow recirculation of interior air which will result in colder output air. On just AC that lower door is opened and that allows hot ambient air to flow thru the Evaporator and will make getting colder temps harder.
4. The SPEC for Class A Dash AC systems is 60 degrees or below. But, almost all systems will get 55 or approach 50 degrees. When properly charged.
5. PROPER Charge is critical for a Dash AC system. TOO MUCH 134a and it will not cool correctly and will kick out the hi pressure switch. TOO LITTLE 134a, and it will not cool properly. Do you know how many OZ'S of 134a they installed? Your Ford requires either 2.25 lbs or no more than 2.75 lbs.
6. 134a systems, you CANNOT charge by the sight glass like Freon 12 systems. A fully charged 134a system will still show bubbles in the sight glass. You MUST install the exact charge to get optimum performance. The Evans/Tempcon Website will show the actual charge for your particular Ford chassis. Doug
Coachmen63
TVX (assuming this is the expansion valve) was taped after installation. Front area of valve is exposed, but rest is wrapped. Tape was supplied with unit when it arrived.
We went on a trip earlier this year to TN and after stopping for lunch the A/C was noticeably warmer. Stayed in TN for a week and on the way home to VA it worked fine. This is whats so confusing. The repair shop had it working just fine and when I drove it home, the A/C was NOT blowing cold air (only cool air). We did NOT adjust the temperature setting, only switched the A/C to MAX and adjusted the fan speed to high. Never got cold.
MEXICOWANDERER
Check for a misbehaving VACUUM control circuit misdirecting air ducting valves.
j-d
Class A's are very interesting in many ways. RV upfitter gets a chassis and installs what s/he likes, is available, is least expensive.
Point is, you probably do not have the HVAC system a Ford truck, van, auto would have. Doesn't mean it's bad, but does mean it's all the harder to troubleshoot especially remotely.
If your TXV was replaced, was the new one then wrapped in insulation, called Press Tite Tape? If not, it will sweat condensation. That condensation will frost, then freeze, covering the TXV in ice. Because of its design, the TXV will shut down, no more cooling.
It happened to us, on a "dealer air" system that used a TXV. Would quit cooling on hot humid days. I'd get out and chip the ice off. Then it'd cool again.
Coachmen63
Did you just put a jumper between the two wires that are connected to the freeze sensor? I found the sensor and felt up to where the tube goes into the A/C box. Probe appears to be well down into the box. One of the A/C lines (metal fitting) next to the sensor was EXTREMELY COLD, so I know the compressor is working. Went through all of the settings on the control knob (vent-A/C, Max A/C, split dash/defrost and everything switched OK. Still confused why the COLD I felt on the fitting is not coming out the vent.
Found this unit at Comfort Aire and they call it a Cold Control unit and they sell for $36.97. I don't just want make sure I don't fry something by doing something stupid.
Ranger_Smith
It is usually mounted under the hood on the ac box and has a copper probe that goes into the box
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
Coachmen63
Good question about the freeze sensor, but I'm not sure if it has one. Sounds like there is more to this system than meets the eye. Any idea where this sensor may be located? May be an unfair question because coach manufacturers put things in different locations.
I'm fairly mechanical and do a lot of work on our coach myself. Learned a lot from working in a true "filling station" when I was younger. Kept up the skill.
Ranger_Smith
Is there a freeze sensor on that. I had the same problem with that ac unit. Bypassed defective freeze unit and it is working like a charm
Where we are now
Steve and Joy
Coachmen63
I clamped off the hose ahead of the cold/hot valve and it didn't make any difference in the coolness of the air (this was suggested on a Tempcon site). So it appears the valve is working properly. I switched the valve to heat and the air definitely got hotter and when I switched it. I heard the door switch, but it sounded like it closed hard, like it might be sticking and that is why I'm thinking we may have a door switching problem or vacuum to it.
