โJul-17-2016 07:40 AM
โJul-18-2016 07:32 PM
Larry-D wrote:
Dielectric grease on the plug prongs and female outlets for the plug prongs. The grease will conduct electricity and help protect the connectors from corrosion. Very inexpensive and works well. Automotive parts stores maybe Walmart. I'm on the same very small tube I've had for probably 20 years.
โJul-18-2016 04:02 PM
โJul-18-2016 03:33 PM
โJul-18-2016 05:43 AM
โJul-17-2016 10:10 PM
guidry wrote:
For my peace of mind, I wrap the plugs with a plastic bag and tape it good then place it on a block of wood or a rock. Never had a problem.
โJul-17-2016 08:11 PM
luvztheoutdoorz1 wrote:
I have a 25ft extension cord that I have to attach sometimes to the shorepower cord to reach the receptacle. Should I try to do anything special with where it connects if it is raining. I know water and electricity do not mix. BTW, the extension cord is rated appropriately for 15A. This is when I am connected to a 15A outlet only.
โJul-17-2016 06:39 PM
โJul-17-2016 04:20 PM
โJul-17-2016 02:37 PM
KE6IRJ wrote:
Ace sells a cord cover for connections. It looks like a giant pill, but they work great.
โJul-17-2016 01:15 PM
wannavolunteerFT wrote:That's probably because you don't turn the power off before plugging into a receptacle. The converters in an RV have a momentary inrush current when first plugged in (due to capacitors in it) and you can hear a zap and see a flash in the dark. This causes pitting and dirt buildup which over time will cause overheating. While you can see what the blades on a plug look like, you can see inside a connector/receptacle.
I found that my TT plug and the end of the extension cord had signs of arcing (burn marks) after I had to use the extension cord when stopped for an overnight without unhooking.
โJul-17-2016 12:46 PM
โJul-17-2016 10:39 AM
โJul-17-2016 10:04 AM
โJul-17-2016 09:57 AM
