Filling fresh water tank while boondocking
lotto38
It is getting to be a pain to lift a container of water and pour into the fresh water opening while boondocking I am wondering if anybody out there has a better idea, like using some kind of pump to get water into the tank.
26 REPLIES 26
skipnchar
Harbor freight has a siphon pump that is started with a squeeze ball. It can be used to transfer fuel, water or any other liquid. Not the FASTEST thing in the world and you'd need to have the source raised above the FW release point but that's not too hard to do. I've always found it easier to either use a 6 gallon water can with spout (I carry five of them) or use my "water thief" to fill directly from the faucet. SOME remote water sources are designed to make use of a water thief difficult but with a little inventiveness it can still be done.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
D_and_A_plus_6
I was wondering what to do myself, and realized I had an extra 12 volt pump, so I plumbed it so I can suck with an 1/2 inch hose and dicharge with a garden hose fitting. Just keep a couple of clean 5 gallon buckets and transfor from the bucket to the fresh water tank. After thinking about it, might be able to winterize the TT with the same pump set up.
JiminDenver
You can use a drill pump and cordless drill
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
HiTech
You can set up valves to use your existing water pump to pump into the tank, and to suck in rv antifreeze as well for winterizing. 2 source, 2 destinations.
Jim
RJsfishin
I bought this at Quartzsite this year. I can't hardly believe anything can work so good.
http://discrv.tripod.com/waterboy.html
It fills just like a waterbed matteress, then a demand pump (cigar liter) pumps the water up into the RV.
And I can use it as a portable water supply to water trees and plants on my little ranchette.
Rich
travelzoo
If at your wet bay you have a valve for selecting city water or tank fill it's rather easy. Just switch the valve to tank fill and draw your water from a container using the anti freeze hose and the RV water pump. I'm sure all rigs are not setup this way, but check it out.
1492
Moderator
Moderator
Moved from Forum Technical Support
Deputy_Chief_P_
We use an inexpensive pump to pump the water out of a 7 gallon water container into our rig. It is pretty quick too. Here is the pump we use: http://www.heartlandamerica.com/browse/item.asp?product=liquid-transfer-pump&PIN=48043&BC=S&DL=SEH3
My advice is worth what you paid for it!
Both of us are Retired Law Enforcement
2003 Pace Arrow 36B
Ansel Adams Edition
3 slide outs
FMCA
Good Sams Lifetime Member
2014 Jeep Patriot Toad
Jack_Diane_Free
I have a 25 gallon tank that I purchased from TSC farm supply that fits in the back of my pickup. I installed a simple home garden spigot. Fill the tank with water, hook up the water hose to the tank and connect to my trailer water tank filler and turn on the valve and let gravity to the rest. Works fine. The empty 25 gallon tank is light and stores in the trailer when the trailer is in storage.
rockhillmanor
I use the KISS theory. No need for engine powered pumps!! :B
They make several cheap hose siphons available at hardware stores. I have one that is nothing more than clear tubing with ball bearing in one end that siphons the water. Just put in and move up and down. Doesn't get any simpler than this!
They make an even cheaper one that is nothing more than a tube with a squeezable ball in the middle to start the siphon. Heck you can even use a piece of garden hose.
https://www.google.com/search?q=syphon+hoses&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&c...
2oldman
Carry extra water boondocking 2008
