โJun-28-2021 09:13 AM
โJun-29-2021 09:27 AM
mr_andyj wrote:
test your city water while you are at it. Mine has up to 500 toxins in it.
โJun-29-2021 09:26 AM
โJun-29-2021 09:20 AM
Mike134 wrote:
I remember my first trip to the boundary waters canoe area in Minnesota.
Us city kids were stunned when the outfitter told us to drink the lake water no filter needed.
I must say we had no issues.
โJun-29-2021 08:53 AM
โJun-29-2021 08:08 AM
โJun-29-2021 07:06 AM
MNRon wrote:
Swimmer spe - Iโd consider UV disinfecting and adding fluoride โtreatingโ the water before it shows up in your tapโฆ
https://en.m.wikipedia.org/wiki/New_York_City_water_supply_system
With that said, weโve kind of taken this thread way off topic. To get back to OP, I always use an in-line filter for any water going into my 5er tank. Additionally, when we used to have a private well, I used to add a small amount of chlorine to my tank from home if it would be sitting more than a few weeks.
โJun-29-2021 06:55 AM
Point is that if NYC is safe to draw from a lake, without any filtration, my home is safe as well. I am taking precautions to ensure that I don't have to worry about my water.
Is New York City water treated?
While NYC's water is unfiltered, it does get treated with chlorine to kill germs, fluoride to prevent cavities, orthophosphate to inhibit lead contamination from pipes, and sodium hydroxide to lessen acidity.Jul 29, 2011
โJun-29-2021 04:01 AM
agesilaus wrote:wildtoad wrote:agesilaus wrote:.
Use a in line filter on the fill hose. I assume this lake water has been checked by the county health dept. It seems to be an unusual water source.
Many people who live on lakes pull water from them for both irrigation and household use. To your point, having the water tested periodically is a good idea. The same holds true for the millions of households the get their drinking water from a well. One should always use a filter at CGโs regardless of the water source. Never know when a water line may break.
Well no, it is by no means the same as a well. For background, I wqent to Environmental Engineering school, was the Technical Director of a environmental laboratory. And we underwent frequent inspections by both the state DEP and the USEPA.
A well is not so easily contaminated, a lake on the other hand is open and who knows what is going into the water. Giardia and Cryptosporidium are frequently found in open water, lakes and rivers. Depending on the state DEP and laws you probably are required to have the local county come by and inspect the water source as well as test the water. And to get a permit. Frankly I'm just not familiar in detail to what inspections and what frequency those inspections would be because I've never seen an open lake used as a water source for a home. But on the other hand if the home owner is happy then who am I to complain?
โJun-28-2021 08:58 PM
โJun-28-2021 08:22 PM
agesilaus wrote:
NYC does not treat it's water. Read up on it and it will impress and surprise you.
No but it is frequently tested for 126 priority pollutants and scores of others continuously. Include E.Coli, Viruses, BOD and other biological testing. Unless the EPA has upped the test count.
โJun-28-2021 08:19 PM
โJun-28-2021 08:12 PM
MNRon wrote:swimmer_spe wrote:MNRon wrote:
Used to drink water straight from lakes in BWCA in late โ70โs (took from below surface)โฆbut by early 2000โs it was recommended to filter it before use. Backpack filters are a pain to use, but we never got sickโฆwhich would be more of a pain.
I too am a little surprised about lake source for drinking water
Then you won't want to learn about where and how NYC gets it's water.
LOTS (most?) cities get water from lakes and rivers, but pretty sure itโs treated before it shows up in your tap. Pulling drinking water directly from surface sources is what surprised meโฆ
โJun-28-2021 07:59 PM
โJun-28-2021 07:42 PM
โJun-28-2021 06:34 PM
