Finding and labeling tv wires?
lj2654
I have had problems with my OTA antenna picking up signals for stations. I just replaced the old 2001 antenna with a Winegard Sensar IV antenna. I am now installing a new signal locater inside and running into problems figuring out which coax is from what source. I guess I need a coax tester to find out? I have a front tv, a bedroom tv, a tv in a basement bin outside. I use a dish tailgater satellite for tv in front. I know behind the front tv there are at least 7-8 splitters with all kind of wiring coming and going.
Do yo just track one wire at a time , get a signal and mark each one, then hook them up accordingly? Very confusing mess to sort through!
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
5 REPLIES 5
accsys
You can also get a very handy 8-Way Coax Tester and make short work of it.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
BarneyS
Moved to Tech Issues forum from DIY.
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
2oldman
Mandalay Parr wrote:
In addition to above you can short them out and measure with an OHM meter.
even easier
Mandalay_Parr
Yes, sort them out one at a time.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
2oldman
I have simply connected wires from a 9v battery ( or any battery) to the cable and measured the other ends to find which was which.
