Firman Power Equipment 3000/3300 Watt Extended Run Time Portable Gas Inverter with Electric and Remote Start W03083 ONSALE $714 free ship.
Newegg Link for Firman 3000 Watt Inverter GeneratorI buy my electronics from Newegg.com and have for many years. I get their On-Sale newsletters regularly. This morning I noticed an Inverter Generator at a really good price on sale for the next 7 days.
Its 3000 Watt, has an RV 30amp plugin and should run a 13.5 A/C unit and everything else on a trailer (except of course you can't run the microwave and/or hair dryer while the A/C is running, this is same for all 3K type inverters).
I have the Champion of the same size and from the specs, this one looks to be close to the same except it has a larger on-board gas tank 1.8 gallons and it has a Remote Start electric fob which mine does not. With that size tank you should be able to run all night (roughly 9 hours so says the mfg).
The claimed noise level is 58db, same as the Champion and others in this class. It weighs 96 lbs (I guess about 10 of that is for the built-in remote start battery)
Disclaimer: I don't work for these guys or even own this unit. But it seems like a very good sale and as far as I can tell it's built on the Powermax technology.
Wildcat2016-295rsx GMC2015-2500HD-DblCab D'max/Allisn+4x4 6.6'Bed
Maxxis235/80/16E;Andersen Ultimate2+4"offset;Airlft1 WirelessComp;GroundCtrl3;MorRyde RubbPinBox+CRE3000;3-Slidecovrs;Champion3100w/DIY ExtndRun;10'Portabote+5hp;Furrion48cam
Visited States
