โSep-12-2018 10:27 AM
โSep-14-2018 07:28 PM
โSep-14-2018 02:10 PM
LarryJM wrote:Ralph Cramden wrote:
Just because its colored black means nothing. Alpha Systems tanks are on many RVs. Theyre black and are not ABS, they're HDPE.
ALPHA SYSTEMS
It's really easy to determine ... just wet the tank with Acetone and if it becomes sticky its ABS unless some other material dissolves like ABS to Acetone.
Larry
โSep-14-2018 12:39 PM
ALPHA SYSTEMS
โSep-14-2018 08:50 AM
Ralph Cramden wrote:Ralph Cramden wrote:
Just because its colored black means nothing. Alpha Systems tanks are on many RVs. They're black and are not ABS, they're HDPE. You cna attempt to glue, flexseal, or essentially cobble together a repair, but if the tank is blow molded HDPE the only permanent solutions that can be counted on 100% are either new tank or plastic welding.
ALPHA SYSTEMS
โSep-14-2018 08:46 AM
ALPHA SYSTEMS
โSep-14-2018 08:35 AM
โSep-14-2018 08:28 AM
Drew A. wrote:opnspaces wrote:
I used plastimend on the rear wall of my black tank. So far it has held up and I don't see any reason that it would fail. They do provide a small piece of fiberglass window screen to use for reinforcement. I bought a bit more screen to make sure it was well supported.
This is probably nothing more than Acetone and ABS chips, but it worked for me so I'm happy.
Link
X2 on this stuff. It works great. Fixed my black tank at a crack where the outlet pipe is. It's now better than new. Not worth doctoring up your own concoction of ABS in my opinion.
โSep-14-2018 07:59 AM
Link
โSep-14-2018 05:03 AM
mobeewan wrote:
In stead of dissolving a piece of ABS sheet you can also do the same with a piece of ABS pipe or ABS fitting to make a paste.
If it is a small crack you might be able to just use ABS glue painted over the crack after cleaning if up and excavating it instead of making a paste.
โSep-14-2018 12:33 AM
โSep-14-2018 12:24 AM
โSep-13-2018 04:24 PM
Sooner Schooner wrote:
Have any of you used a Flex Seal product to repair a crack in a holding tank?
โSep-13-2018 04:02 PM
โSep-13-2018 06:35 AM
Link
