Feb-21-2021 04:01 PM
Mar-02-2021 09:46 AM
Mar-02-2021 09:35 AM
Mar-02-2021 09:16 AM
pianotuna wrote:
Hi Steve,
On the same search I found this:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiawbfU75HvAhVeTDABHYfqBSYQ...
"Through experimental analysis of batteries, we draw the conclusion that LiFePO4 battery has a long cycle life, good safety attributes, a high theoretical capacity, low environmental impact and other characteristics; however, it also has many shortcomings, such as need to prevent over-charge, over-discharge, and over-temperature. Otherwise, utilizable capacity of the battery will decrease rapidly, and cycle life will reduce quickly."
Translation: LiFePo4 are unforgiving of any abuse and may bite you in the behind.
Mar-02-2021 06:26 AM
Mar-02-2021 06:19 AM
Mar-02-2021 05:46 AM
Mar-02-2021 04:45 AM
pianotuna wrote:
LiFePo4 can be made to work well. Any battery bank can do that, but for LiFePo4, there are lots of extra hoops to jump through. Such as a way to limit charging from an alternator, a truly compatible converter. There are also high temperature concerns, starting at 86 f and possible low temperature "cut off" depending on the design parameters of the battery management system.
With SiO2 there are few of the above concerns.
Li prices are dropping madly. I would speculate that the DIY crowd are already almost at the point of parity in initial cost for the same number of usable amp-hours in lead acid. I did see an LiFePo4 "roll your own" for $480 using cells with cosmetic blemishes. (Grade B)
Mar-01-2021 07:14 AM
Mar-01-2021 04:39 AM
3 tons wrote:StirCrazy wrote:3 tons wrote:
“ 3 tons the quote from the article qualifies itself:”
“Qualifies itself” how so??
BattleBorn (and every other LFP offering I’ve seen), clearly state that LiFePo4’s can be discharged to -4f, with no suggestion or implication otherwise - are we to dismiss this?? In proper context, ALL chemistries tend to get sluggish in *below freezing temps (a no brainer), so this is precisely why context matters!!
*with the possible exception of SiO2, though curiously, I’ve not found an independent (i.e. non-vendor) white paper on SiO2.batteries...
3 tons
No at 0C and below Sio2 still lose a large chunk of there capacity, actualy more than LFP but they work to a much lower temp. the graphs are out there. they dont lose as much capacity as Lead acid but lose more than LFP so there in between. still a good option if weight size are not issues and temp is. but I think if some one decided to go SiO2 they should change out there chargers also as there is no sulfication (sp) with SiO2 so will the desulphacation setting dammage them? Mind you I think anyone investing in batteries should also be investing in the charging system by having one that you can customize the settings and taylor them to your battery type. I always laugh when I see some one spending 1 or 2000 bucks on batteries but wont spend 200 bucks to hange out the charger section of the converter or there solare controler.
Steve
Agreed, those are all great points Steve, kudos Sir, I can see that you’re doing your all important homework!...I definitely see SiO2’s as a viable consideration, though it’s not been made clear what kind of SOC metering is compatible - nor sure about equalizations - maybe you have a white paper?
From the little I do know, PT is going with SiO2’s (mostly due to -40d temps), and in balance he’s surely making a great choice...
As far as LFP charging goes, I’m able to easily do this using a standard Progressive Dynamics 9245 using the optional Charge Wizard pendant set to Boost mode...Post BMS balancing regime (as verified via Victron BMV-12) I simply defeat the charger...
3 tons
Mar-01-2021 04:34 AM
pianotuna wrote:
The only graphs I can find say that SiO2 are at about 80% of capacity at -20 c (-4 f), and that LiFePo4 are about the same.
Of course if we drop down another 10 degrees to -30c (-22 f) then SiO2 are at 60% and LiFePo4 there is no graph I can find.
Feb-28-2021 09:39 AM
3 tons
Steve
Feb-28-2021 09:35 AM
Feb-28-2021 08:20 AM
Feb-28-2021 07:27 AM
3 tons
Feb-27-2021 11:32 AM
