Take a look at the first few pages of
This Install and Use Manual.I've seen better diagrams, but this'll explain that the fridge needs to be installed in a way that convection carries heat off the coils and out of the coach. It also works out that if the fridge is in a slide, so the venting isn't straight up and out of the coach, then it needs a fan to create that circulation.
That, and baffling to prevent a dead space where air swirls but doesn't flow up and out.
