โApr-22-2016 02:52 AM
โMay-03-2016 08:01 PM
โMay-01-2016 10:30 PM
โMay-01-2016 09:38 PM
โApr-27-2016 12:26 PM
โApr-26-2016 11:07 PM
-Oz- wrote:Its slowly but surely coming together. I mounted up the controller and the 50 amp breaker. I'll run the solar through the breaker. I am wondering if I need some type of breaker between controller and batteries, maybe fuse style?grizzzman wrote:Calkidd wrote:
Thanks again for those who were informative and encouraging. I'll let this thread die. I'll update it later with my installed, inefficient, underrated system.
For what its worth, If in the same situation i would do the same.
Please keep us informed.
Me too. Go for it you have nothing to lose, some to gain, and the possibility to upgrade at a later date.
โApr-26-2016 08:27 PM
โApr-25-2016 07:42 AM
โApr-25-2016 07:24 AM
โApr-25-2016 04:29 AM
Almot wrote:
Details are being slowly dragged out.
โApr-24-2016 11:26 PM
โApr-24-2016 10:34 PM
โApr-24-2016 09:51 PM
โApr-24-2016 08:56 PM
โApr-24-2016 07:38 PM
Almot wrote:Calkidd wrote:
I have nothing to loose using these panels. I think I will use 3 panels starting out.
Nothing to lose, except for size/current efficiency. Those 208W look same large as mine 245W, and PWM will process less than half of available wattage.
If Trimetric clips it off like - apparently - it says in the manual, why only 3 panels, what is the purpose? To see if solar will make any energy? ๐ It will. 21A is a very modest system, even die-hard Handy Bob has 2 times bigger equivalent, considering tilt. Enough for a minimalist but not if you want to run your rig on solar the same way as on grid.
