Fridge Not Cold On Gas
dano73
Hi all, I'm back. My dometic 3804 doesn't cool on gas but works fine on ac. I was told the only thing it could be was the chimney. Well, I removed the fridge and the baffle is indeed in there, and the chimney is clear, with very light surface rust. The baffle has light rust also, which was expected, but solid, idk if it should even be replaced, anyone know a good source? So where else should I check, I thought it was the board, but was told no.. Any other ideas? Btw pilot is fine and stays lit, Wic pressure is good, burner and orifice clean.
19 REPLIES 19
darsben1
dano73 wrote:
Anybody beside doug have any ideas??
Follow the troubleshooting guide in the service manual?
Traveling with my best friend, my wife in a 1990 Southwind
wnjj
I'd go with Doug's ideas. He's got more experience than many more who may post.
Your flame probably isn't as hot as it should be, for one of many reasons.
dano73
dougrainer
First, It is NOT the only thing you were told. What you were told is almost the LAST thing that causes it. HOW do you know the LP pressure is at spec????? Very few people have a manometer, especially someone that goes to the Internet for help. Also, there is NO pilot flame. JUST a standard flame. And NO, a control board would never be the cause if the flame stays ON and you do not get a check light. Doug
darsben1
I believe this is your service manual
http://bryantrv.com/docs2/docs/AES.pdf
If not you can find most of them at
bryantrv.com
