โFeb-09-2015 06:49 PM
โFeb-25-2015 07:54 AM
dougrainer wrote:RJsfishin wrote:
Doug,
I replaced the spark sensor wire a while back when I first got here. It had trouble lighting at times, sometimes going into failure mode after several tries. That fixed it now never fails to light,.....well after I got the gap adjusted right that is.
This is a whole nother problem, and not a very serious one at that. And one it may have had since new
Thanks.
Long shot would be the Piezo ignitor tower on the control board is loose. I find this on 1200 models when the spark electrode spade is removed and you do NOT use a back up screwdriver to hold the piezo tower tight on the board to pull the spade terminal loose. If you pull the spade without securing the tower, you pull the tower solder pins loose. The fix is to either replace the board or pull the board and resolder the 4 solder pins on the tower on the board. This type problem will allow the Piezo to spark, but NOT allow the return AC flame signal to get to the board for processing that there is a flame. So, you may indeed need a new board. Doug
โFeb-23-2015 05:01 AM
RJsfishin wrote:
Doug,
Thanks.
โFeb-22-2015 02:49 PM
โFeb-21-2015 10:01 AM
RJsfishin wrote:
I am going on 21 days now w/ no flame out. I'm now wondering if is really isn't a control board overheating problem that the little fan is maybe helping it. More time, more summer will tell. Trouble is, after this AZ trip, I am not into hot weather camping, so may never know.dougrainer wrote:RJsfishin wrote:
This is a normal updraft thru the roof vent, no fans anywhere,.....until today,....I installed one 4" at the bottom of the vent cover. Then, a catastrophic event happened. I had the fan running, and was tightening the last screw, when my screwdriver slipped, went into the fan,....2 blades gone instantly, and very out of balance !!!!@#$%^
Back to the vendor for another fan, 4 bucks down the tubes !
New fan working perfectly, except I picked up the 12 volts off the gas valve, so the fan only runs when the fire is lit. I mite have to change that. The good news is, no F code all day. Bad news, the sun was not as hot as it has been the last 3 days, so while I mite have improved the situation, I won't know till it gets hotter here.
No, no low voltage problems,....14.6 at the gas valve when burning.
Thanks for all the ideas.
While you have found a work around(until the sun gets hot again), you still have a problem. You ONLY need rear fan/s to help with cooling, NOT to keep a refer from completely shutting down. Remember, you have a Flame out code. Doug
โFeb-21-2015 07:27 AM
โFeb-21-2015 07:01 AM
โFeb-11-2015 06:30 AM
โFeb-11-2015 04:42 AM
โFeb-11-2015 04:05 AM
โFeb-10-2015 06:48 PM
โFeb-10-2015 05:18 PM
โFeb-10-2015 03:33 PM
โFeb-10-2015 03:17 PM
marcsbigfoot20b27 wrote:
It's extremely difficult to troubleshoot your problem over the internet when we don't know what year, make, model of trailer with or without slides, etc.
โFeb-10-2015 09:53 AM
dougrainer wrote:doug my fault imeant voltage drop is what he is experiancingnewman fulltimer wrote:
If in a hot climant running the ac its pulling alot of amprage your converter or basttery is not keeping up for the smount needed. Once the temp cools of the demand goes down voltage goes up and fridge comes on.
Check wiring connectoins for corrosion and tightness battery for proper voltage
I want you to read your post again and think about what you stated.
1. The Roof AC is pulling AC amps
2. The refer is on LP and the 12 volt controls pull milliamps
3. The Converter only supplies 12 volt current to the RV and would NOT be affected by the Roof AC 120 volt amp draw.
4. Remember , he is on LP on the refer not 120 and even if he was on 120 on the refer, the amps would be 2.6 and the refer would not throw a LP code(F). Doug
