Fuel/gas/propane lines hanging/drooping on my rv?
sscheitel
I have a few of the rubber gas/fuel lines hanging down on the underbelly of the rv. None of which are for an outdoor BBQ.
Everyone that I encounter says to zip-tie or pin them back up but what do I screw into?
I don't have an issue with zip-tying, banding and tacking back up...my concerns are:
- where do I screw into? I know I need to avoid using a longer screw that is needed.
- avoid the path of the slide outs
- and the cursed....too long of a screw going through to the floor :eek
Where is the best place to screw into the underbelly? into wood? metal frame with sheetmetal screw?
Also, there appears to be many spots under the RV on the underbelly where there are pre-drilled holes in the underbelly where it looks like they should have put in a screw to fasten the underbelly but didn't....did they just get lazy? Are there just more holes then there are actually needed? Do they simply pre-drill holes throughout the entire underbelly now knowing which TT model it will be attached to and have more holes then needed?
thanks guys and gals ๐Ÿ™‚
9 REPLIES 9
Joe_Way
sscheitel wrote:
Also I see quite a bit of expanding foam where the hoses go into the coach....didn't now if I could push the excess back up inside?
Don't push the foam up inside--it will break loose and will no longer seal. If you don't like the appearance, cut off the protruding part with a sharp knife.
sscheitel
drsteve wrote:
Hanging down? As in ready to scrape the pavement, or just not super tight to the underbelly?
the latter....drooping with 6 inches at the apex from the underbelly...still a good 8-10 inches from the road.
Let me take pics and post them here....this way the people that can advise will advise but now holding back because there are so many unknowns ...please stay tuned
drsteve
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
sscheitel
Good point. No harm in doing that
fj12ryder
JMO but I would take it back and at least make the dealer aware of the problem. That way if you have issues further down the line you've at least let the dealer know there was a problem from the beginning. Honestly you shouldn't have rubber lines hanging down.
Howard and Peggy
"Don't Panic"
sscheitel
Nah not necessary. I am sure they all of this is under the Jayco guidelines of normal and acceptable. This is my type "a" personality sprinkled with a little OCD that's causing me to take up oncern with these little things.
Plus I love to fix stuff and an RV is one big toy ๐Ÿ™‚
cmeade
2018 Jayco needs to go back to dealer and have them figure out what to do!!! If problems arise they will be on the hook!
sscheitel
2018 Jayco Jay Flight 32BHDS - 36ft travel trailer with bunk house and double slide outs
wolfe10
Please tell us what RV you have-- that will help with answers that are relevant to your RV.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
