โMar-22-2015 12:04 PM
โMar-23-2015 03:56 PM
smkettner wrote:
Yes and I have removed and reinserted a few multiple times on my WFCO panel without issue.
With reasonable caution you should have no problems. Strain relief is not a huge issue at this point. No one is moving, bumping, twisting, pushing on those wires once the panel is back in place.
If you are not comfortable with the adjustment then by all means just pigtail it.
โMar-23-2015 02:20 PM
Bud
USAF Retired
Pace Arrow
โMar-23-2015 01:57 PM
enblethen wrote:
Even if you break the strain relief they are available at most hardware stores.
They are used in some service panels that have flat sides and rounded ends in the panel opening
โMar-23-2015 12:04 PM
Bud
USAF Retired
Pace Arrow
โMar-23-2015 11:21 AM
โMar-23-2015 11:12 AM
โMar-23-2015 10:36 AM
smkettner wrote:
Yes a bit tedious but I would move the wires and strain reliefs around if at all possible vs adding a wirenut connection and pigtail.
โMar-23-2015 09:52 AM
โMar-23-2015 06:50 AM
BurbMan wrote:
The NEC allows the use of wire nuts inside a distro panel, it's considered a junction box. Rather than go through all that work you can add a short pigtail on the wire(s) that needs to be moved to make it long enough, assuming there is adequate room in the box for one or more wirenuts.
โMar-23-2015 06:05 AM
โMar-23-2015 04:46 AM
Golden_HVAC wrote:
If you just remove the cover for the 120 volt circuit breakers, and determine what CB feeds each of the loads, and what you want to move, it will be easy to move one load from CB #1 to CB #2 leg.
Fred.
โMar-22-2015 06:05 PM
โMar-22-2015 05:49 PM
Porsche or Country Coach!
โMar-22-2015 03:57 PM
pianotuna wrote:
Hi,
If you boondock and use an inverter there is a case to be made for having all the items you do NOT wish to run via the inverter on one leg.
You could still have each air conditioner on separate legs--just don't turn it on when using the inverter.
