โJul-15-2016 05:14 AM
โJul-15-2016 01:00 PM
alank2 wrote:
I'll try my Yamaha dry then - I started it up and turned off the fuel switch and waited for it to run out. It does indeed take a few minutes...
โJul-15-2016 11:39 AM
Sam Spade wrote:
Answer #2: There will be a little left but it isn't a little that you are worried about. The problem occurs when some evaporates and is replaced by more which then evaporates and is replaced........
โJul-15-2016 11:36 AM
alank2 wrote:
Question #1 is - if you leave it wet and turn off the switch, will it dry up?
Question #2 is - if you turn off the fuel and run it until it stops, will the carb be completely dry? Or will there be gas left that could dry out and get gummy?
โJul-15-2016 10:36 AM
โJul-15-2016 10:24 AM
โJul-15-2016 09:02 AM
โJul-15-2016 08:53 AM
โJul-15-2016 08:47 AM
โJul-15-2016 08:30 AM
โJul-15-2016 08:17 AM
โJul-15-2016 08:12 AM
โJul-15-2016 08:10 AM
โJul-15-2016 08:08 AM
โJul-15-2016 07:37 AM
โJul-15-2016 07:28 AM
