Generator won't start
Artum_Snowbird
Onan 4000 gas. I hear a click, then a rattle but it won't turn over. Battery voltage is 13.6, connected to shore power. Ran jumpers from battery to starting solenoid and negative to ground.
Suspect solenoid. Anything else? It ran a couple weeks ago. Drove to the desert in a rainstorm.
Hot outside now. Gen has only 80 hours on it.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
8 REPLIES 8
Juzaxadar
Sounds like the problem I'm having. Mine doesn't have that bendix sound (the spinning whine). Was it your the solenoid?
2000 Minnie 31C V10
Artum_Snowbird
Measured input and output solenoid voltage. 13.6 in 2.8 out. Removed solenoid 12V 307-2586 model number of solenoid. Thanks everyone.
Mike
gbopp
Are your battery terminals clesn snd tight? A little corrosion can cause problems.
Kpackpackkelley
Reach in on the left side housing and try to turn the flywheel by hand. Starter gear may have broke off.
enblethen
How long and what gauge are the cables used.
It could be bad starter.Can you turnover genset by hand. Might have access for socket on engine end.
What series of Onan 4000, full model information and series number.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
EdTheEdge
Are you getting an error code?
HaRVey - 2013 Thor Chateau 22e
Artum_Snowbird
enblethen wrote:
Sounds like low voltage. If you can connect jumper cables directly to the genset.
Did that directly to battery terminals.
Mike
enblethen
Bud
USAF Retired
Pace Arrow
