โApr-08-2018 02:25 PM
โApr-09-2018 03:50 PM
wa8yxm wrote:
Most of those in-line blade fuse holders are only rated for 20-30 amps (Some less) so you are really working it. As you did, cleaning it up and tightening is the "Fix" but you may wish to consider changing to a different type of fuse holder.. One with a higher rating, and sorry. I do not have any suggestions. Other than possibly a Maxi Fuse holder. Do not know the ratings on those.
โApr-09-2018 03:31 PM
โApr-09-2018 02:52 PM
kmb1966 wrote:dougrainer wrote:
I did not state 10 amps per coil.
I stated that each coil is PROTECTED by a 10 amp fuse. Doug
I tried putting my multimeter on amps and see what it is pulling but I could not get an accurate reading. I pushed 'store' and then took the reading, it only read 0.01 so I'm thinking I took the reading incorrectly, or it is only pulling amps at the moment that the 'store' button is pushed. But since it does not blow a 40 amp fuse, but it will blow a 15 amp fuse, I think I can assume it is pulling more than 15 amps, but less than 40. I might put a 30 in there and see if it blows the 30. New fuse holder gets delivered in a few days.
โApr-09-2018 10:03 AM
โApr-09-2018 06:43 AM
โApr-09-2018 04:47 AM
โApr-08-2018 09:09 PM
โApr-08-2018 08:39 PM
โApr-08-2018 05:54 PM
โApr-08-2018 05:51 PM
โApr-08-2018 05:25 PM
time2roll wrote:
Is 40 amp the proper fuse? (appears correct according to Doug)
Maxi fuse holder: http://www.genuinedealz.com/maxi-fuse-inline-fuse-holder-w-6-awg-leads-up-to-60a
Not going to melt at 40 amps.
โApr-08-2018 05:16 PM
โApr-08-2018 05:09 PM
โApr-08-2018 04:48 PM
