Onan 4000 Microlite 4KY26100E
My generator has had a new fuel pump, fuel filter, fresh oil and filter change, brand new carb yesterday, as well as spark plug and air filter.
When I go to use it, I have one shot at getting it started. Here are the scerios:
1. Push start on the remote control and when it starts to run I let go of the button. It runs AC and fridge for 3 hours +. I pulled into gas station and pushed stop button. Filled up with fuel, moved the rig, pushed start button at the dash and it just cranks and cranks and cranks. What the heck happened?? We drove about 20 minutes and I pulled over so I could listen: pushed start on the dash and it fired right up. About an hour later we got where we were going, stopped the generator. Also note that I saw the lights flickering a little before I shut it down. I went out and listened and it was sounding a little choppy, almost like it wanted to surge (but it didn't) and then cut down too low. It was a very very slow process, but remained evenly running... Weird. Anyway, An hour later I tried to restart and it just cranks again... Now we are laying here sweating to death with no ac, so we are pitching a tent tonight.
2. On a different day, I started the generator and it sounded like it was about ready to run, but I let off of the start button too soon apparently and it never really got started. Pushed it again and now it only cranks and cranks, just like listed above.
On both cases, I've taken off the fuel line from the carb and its spitting fuel. Also, pulled spark plug and it has spark while cranking, but there is no fuel spitting out of the spark plug hole. Carb is brand new, choke and throttle linkages are free.
Not sure if choke is adjusted correctly, how do I know where the set screw should be set?
So anyway my questions are:
1. Why does it not restart after I push the stop button? It restarted after 20 minutes of driving, but has yet to restart after sitting. Am I looking at vapor lock? Fuel is full fellas, don't go there.
2. Why can't I start it again after I let off the button too early? Did I trigger a safety switch?
All of this is started and shutdown on zero loads. Thanks :)!
