โFeb-25-2015 03:50 PM
โFeb-26-2015 05:20 AM
Trackrig wrote:Rmack1 wrote:Trackrig wrote:
If you can comfortably stand on the ground, it's level enough for the generator.
Bill
Thanks for that, Bill, but being a backpacker, hiker, (not to mention rock climber), I'm pretty comfortable on some quite un-level ground. Could you be more specific? I might notice it if I had to lock one knee and unlock the other to stay upright, but that would probably put a generator sitting on that ground several degrees out of level.
I'm guessing this is an issue of when the lubricating system can't cycle, or the carburetor can't dispense fuel efficiently that would limit it's off-level capabilities. It needs someone with knowledge of the internal design to really know the limits.
OK, let's try this. If you put your camp chair sideways on the slope and could set in it for a long time without a lot of bother, then the slope isn't going to bother the generator.
I own a Coleman 1750, 3 Honda 2000s, a Champion 4000, a Briggs & Stratton 6000, a Kohler that's so old I don't know what size it is, and an Onan 7500 - the only thing I worry about is if they're level enough to refuel.
Bill
โFeb-26-2015 04:35 AM
โFeb-26-2015 03:54 AM
โFeb-25-2015 10:55 PM
โFeb-25-2015 08:17 PM
โFeb-25-2015 07:52 PM
Bill
โFeb-25-2015 06:29 PM
โFeb-25-2015 05:30 PM
โFeb-25-2015 05:29 PM
โFeb-25-2015 05:10 PM
weasel4 wrote:
My nephew has an ocean boat with the Yamaha, it's anything but level,works fine
Btc
โFeb-25-2015 05:08 PM
ScottG wrote:
If the gen will run, it's level enough (it has nothing to do with how comfortable it is for you ;)). The problem arises when it's so far out of level that the low oil sensor is tripped.
โFeb-25-2015 05:05 PM
Bill
โFeb-25-2015 04:48 PM
โFeb-25-2015 04:47 PM
