โApr-01-2014 07:32 AM
โApr-10-2014 07:37 PM
โApr-03-2014 08:13 PM
โApr-03-2014 05:44 PM
teddyu wrote:The specific page is HERE. One line: This is done by connecting the load side hot terminal to the line side neutral terminal through a resistor calibrated to conduct a small amount of current at 120V (approx. 8-10 ma). - That would allow current to flow through one winding only in the diagram. My early experience with GFIs (I still use the old term) was that the test did not work without a ground.
... Check my source - www.mikeholt.com. ....
Reese Dual Cam Straight Line HP Sway Control
โApr-03-2014 12:29 PM
โApr-03-2014 12:04 PM
โApr-03-2014 07:15 AM
โApr-03-2014 06:28 AM
โApr-03-2014 06:24 AM
Hogan wrote:
NEED HELP! I have chased this problem the better part of 2 days and $300 and had no luck!
When my 2008 HHII 32.5UKTG fifth wheel is plugged into 110V. and the converter is running the ground fault outlet in the kitchen will not trip when the test button is pressed. If the converter is not running and still plugged in the test button works correctly. The converter is on the same circuit as the ground fault outlet which is a good thing.
If I remove the batteries from the system by removing the chassis ground wire or one of the positive post wires with the converter running the outlet works just fine. If appears I have an open ground when the batteries are connected and the converter is running.
I have replaced both the outlet and the converter with no change other than to my bank account.
Do I have to chase every 12v circuit checking for open grounds?
HELP I am at a loss.
โApr-03-2014 06:00 AM
โApr-02-2014 06:38 PM
teddyu wrote:
Something is wrong with the GFCI receptacle or its wiring. Pressing the test button DOES NOT induce a ground into the system to trip the GFCI. The test button shunts current from the hot side to the neutral through a current limiting resistor. Conclusion: the GFCI is bad, the neutral is open, or the neutral and ground are reversed - in other words the wiring to the GFCI is messed up. JM2ยข...
โApr-02-2014 04:22 PM
โApr-02-2014 10:56 AM
โApr-01-2014 02:55 PM
โApr-01-2014 08:44 AM
