โMay-24-2023 04:55 PM
โMay-28-2023 09:03 AM
Almot wrote:StirCrazy wrote:
I like the idea of the mat, but it would be better if you could put a rheostat on it to control the power going to it. that way you could adjust it to say 85 degrees which would be perfect for a floor temp.
Looks like heated mat is a no-go. 5 ft long snow-melting mats are too powerful and those with less power are 3 ft long or shorter. Many complaints on horrible smell of indoor heated mats. Snow-melting 5ft mat looks like made from the same rubber-ish material, should smell too.
Under-carpet heated mats in hardware stores are not made to be walked on, they are to be laid under carpet or tiles. Too bad, I like the idea of heat coming up from the floor, lived once in apartment with heated floor, loved it.
โMay-27-2023 11:05 AM
โMay-27-2023 09:51 AM
โMay-27-2023 05:20 AM
โMay-26-2023 05:36 AM
โMay-25-2023 11:56 AM
โMay-25-2023 08:45 AM
โMay-25-2023 05:17 AM
โMay-25-2023 03:51 AM
โMay-24-2023 05:30 PM
JimK-NY wrote:
Your post brings all sorts of issues to mind. First if you have an electric hook up, why are you suffering with a cold RV? Why are you not using a space heater? Second, when you get up in the morning, why not use your furnace? Mine does a good job in a few minutes.
This is a separate issue, but I cannot imagine spending an hour making breakfast. Coffee and oatmeal just require some boiling water. Eggs are even quicker.
โMay-24-2023 05:17 PM
