It sounds like the high limit switch is shutting it down. Check your intake and exhaust for blockage from insect nests or some such thing. If there is an obstruction in the exhaust, for example, heat would build up and shut down the furnace. I once had a similar problem and found about a cup of bees and other flying critters in the combustion chamber. Check out the manual
here.
DW and Me
2016 Riverside White Water Retro 195
2014 Nissan Titan SL Crew Cab
Formerly, I used to work for the department of redundancy department.
Life in Black and Blue
