Heater won't stay lit
H2oSprt
My heater will fire, light then go out. I changed the regulator and got a new propane bottle. Any ideas?
Thanks
15 expedition El ecoboost
2008 Jayco 12hw
9 REPLIES 9
bigfootford
Nomad II
Nomad II
H2oSprt wrote:
I figured I'd come close this up for others in my situation. I ended up having to change my circuit board that controls the ignition. Easy 5 min fix, fires up and runs great.
Yea, thanks for ending your thread... So many folks leave it hang makes the thread worthless most of the time..
Congrats...
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Bilstein shocks, air bags/pump, EU2000, PD 9260, Two Redodo 100ah Mini's, Aims 2500 Conv/Inv, 200W. solar, Morningstar Sunsaver 15A/ display panel, Delorme/laptop for travel, Wave-3 heat.
H2oSprt
2008 Jayco 12hw
bigfootford
Nomad II
Nomad II
H2oSprt wrote:
So it's an Atwood heater model 1522. The heater will blow air, auto igniter will click, I can feel a burst of hot air and then it will go out. The code on the heater reads incomplete ignition. I took it apart today, it's not dirty everything looks fine. My buddy thinks it's a circuit board issue. Might try replacing that next.
You should hear the flame, it is quite noisy.
There is a delay that occurs from when the fan starts to blow and then ignition. Sounds like you got to that point....
Here is the sequence for your 1522:
3. As the valve opens, the board sends a high voltage
spark to the electrode at the burner. The board detects the presence of a flame. If the flame is not sensed after approximately six seconds, the board will lock out (three try for ignition, one hour lockout and then three retry), shutting off power to the valve.
4. If the system does not ignite and the thermostat remains closed, the blower will remain on until the thermostat is reset manually.
Here is a link to the PDF service document for the 1522, I do not know which options you have but the call for heat is the same..
A reminder to thank Bryant's RV for providing unselfishly the many helpful documents he provides...
http://bryantrv.com/docs2/docs/hflamefurn04.pdf
For all of you reading this... Bryant's rv has an excellent website with lots of documents and parts....
This should be bookmarked by all:
http://bryantrv.com
Jim
H2oSprt
2008 Jayco 12hw
bigfootford
Nomad II
Nomad II
Here are a couple of helpers to understand the lighting and staying lit sequence.
http://www.rvforum.net/miscfiles/Furnace_Trouble-2.pdf
http://www.ducktec.com/furnace-trouble-shooting.html
Jim
Crazy_Ray
Needs cleaning???
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
Triker33
sail switch?
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
tony_lee
"Need more info:"
yes, the exact sequence of sounds and flames and airflow is needed for accurate remote diagnosis.
brand and model of the heater etc etc. Is it a water heater or furnace?
Does the click of the solenoid valve coincide with the flame going out, or does the flame go out and then the flame failure deenergises the valve
Tony
Lots of photos with comprehensive captions at MY PICASA Album
Spotwalla map of our travels - Our Travel map
HMS_Beagle
Gas valve on the heater? Flow sensor on the fan? Need more info:
Does the fan kick on first, then the burner fire and then go out?
Or does the burner never fire?
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
