โAug-05-2018 08:32 AM
โAug-05-2018 06:02 PM
Artum Snowbird wrote:
I think it is indeed highly likely that the problem will be in the connection plug. I would get some electrical spray and spray the connections, working them in and out and spray again. The proper spray dries fast and cleans too.
You should also check the main feed wires. They are heavily loaded wires when the motor is lifting, and a loose connection in the main feed could easily cause your problems too.
โAug-05-2018 03:33 PM
โAug-05-2018 09:22 AM
campingwiththoreau wrote:
2002 Bigfoot truck camper with HappiJac wired jacks and cable and remote. (the jacks are
replacements put on in 2014)
In the last couple years the remote would only work intermittently.
Now- wonโt work at all (this is the remote with rj11 coiled cable)
When I plug in the cable- the remote starts green then goes to orange then off and
cycles like this only. There is some sort of power reaching the jacks because when I hit reset
you can hear the jacks make a noise for only a secondโฆ the other day even with
the issues described here the front left jack was working for a while.
Happijac sold me a replacement remote and cable. This new remote offers the same results.
Also- as per Happijac - I plugged my cable straight into the logic board. I get the
exact same results when I do this.
Im hoping someone here has an idea how I might trouble shoot this issue. Happijac wants
me to buy a new wireless setup- I am on a fixed income and really want to fix what I have.
Please help- will try anything. Because its intermittent and/or some sort of loose connection
or power issueโฆthere should be a fix???
Regards,
CWT
