The driver's side front landing gear will not move under load. Motor runs gears spin. Venture mfg., 2008 28E33SA Titanium by Glendale.
I would like to take the whole thing out (tube sections) But I can't figure out how to do that. I unbolted it at 2 locations but it appears to be heavily siliconed in where it meets the floor with a metal plate.
So I took off the motor, and the gear box. (gears look fine)
I then took the top cover off the tube. (again gears look fine) It is hard to tell but I believe the bottom gear maybe slipping on the shaft or the threaded shaft may have a bad spot. (stripped?)
I was able to get the top horizontal shaft and gear off,
But I can't seem to get the bottom gear off the main vertical shaft.
Don't see any pin.
Any Ideas?
Thanks
"Relax, Don't Worry, Have A Home Brew"
Forest Metallic Green;
2011 F-350 Super Duty Diesel Crew Cab, LB, SRW, 4x2
2008 Glendale Titanium 5th Wheel, 28E33SA
Dry Pin Wt.1925lbs. Dry Wt. 9,691lbs. GVWR 12,302lbs.
