โMar-11-2016 11:24 AM
โMar-13-2016 02:43 PM
Bud
USAF Retired
Pace Arrow
โMar-13-2016 01:28 PM
myredracer wrote:
Seeing the photo of what you actually have makes it look like quite a simple fix (from here). There will be a hollow cavity in the underside of the cabinet with wires over to where the radio is. If it's the typical Jensen radio, it's held in place with 4 screws accessible through the holes in the faceplate and will come out as a complete assembly. There has to be 12 volts in there for the radio and may go around the corner to the 12 volt outlet at the TV plate (with a co-ax outlet). If you can't find the bad splice, you could cap off the old wires at the light and pick up new 12 volts at the radio and fish new wires inside the cabinet cavity.
โMar-13-2016 11:27 AM
Rmack1 wrote:
That's exactly mine! Even the upholstery and curtains are the right color. It might actually be photos of mine before I bought it.
The fixture in question in under the cabinets over the dinette. Everything else works.
โMar-13-2016 10:43 AM
Bud
USAF Retired
Pace Arrow
โMar-13-2016 10:30 AM
enblethen wrote:
I found some good pictures on a site. Is this like yours?
I would look for installation instructions for the radio. The face should come off gaining access to the mounting screws. That should let you into the wiring for the radio and TV.
Does the radio work?
What about TV?
If yes odds are the problem is behind the radio!
โMar-12-2016 07:12 PM
Bud
USAF Retired
Pace Arrow
โMar-12-2016 06:12 PM
enblethen wrote:
Would you post the true model number?
โMar-12-2016 05:29 PM
Bud
USAF Retired
Pace Arrow
โMar-12-2016 03:13 PM
myredracer wrote:
Not sure which model you have - 2104S? Below is a pic of slide area - shows 1 light in the slide. Is this it?
Is there a separate switch or integral with the light(s)? As mentioned, first suspect would be a splice that has gone bad. They don't exactly do a good job at the plants of twisting stranded wires together along with a wire nut. If there are no other 12 volt problems, it would most likely be a splice problem, then damaged wires.
If the light is in the slide, look for the wiring under the slide. There may be a junction box that is accessible. Check for a bad splice and power there. There will be a flex arm thingy that lets the wire move as the slide goes in and out. See if anything is damaged there. Try pulling the wire out from behind the light. Sometimes there is a lot of excess wire that gets shoved in behind the light and there could be a spice in there. Same with the switch.
I don't think there will be much to gain by pulling the radio out to access wiring. There is no rhyme or reason how they run 12 volt wiring and the slide light could be connected to a 12 volt circuit feeding other items anywhere.
โMar-12-2016 02:20 PM
Bud
USAF Retired
Pace Arrow
โMar-12-2016 12:37 PM
Rmack1 wrote:Bumpyroad wrote:
I'd look into prying up the floor of that cabinet to see where the wires lead and how you can fix situation. you can always put another thin bottom board into that cabinet to cover the hole you make. if you can't pry it at all, just cut a hole in the floor directly above the lamp mounting area.
are there multiple switches that control that light? perhaps bad switch?
bumpy
Wow. I'd have to grit my teeth to tear up that nice cherry wood cabinetry. I was going to take off the CD player/radio and see if I could get at the wires where the splice might be failing. Going to be challenging, because the flat screen TV is mounted right in the way. Oh well, good thing I'm retired!
โMar-12-2016 09:04 AM
โMar-12-2016 08:36 AM
โMar-11-2016 04:24 PM
enblethen wrote:
Radio could be fed off that circuit.
