Vinal Insert Trim
craig7h
Nomad II
Nomad II
My early spring project is to replace the vinyl insert trim, on the outside screw channels. Most of whats on has shrunk thus needs replaced. My question is whats the correct way to install so the shrinking does not happen again
Itasca Meridian SE 36g
Road Master Tow Dolly
6 REPLIES 6
MFL
Nomad II
Nomad II
Lynnmor wrote:
As you install the trim, don't stretch it out but instead push it back a bit to "bunch" it up.
This is what I have done on past units, and no further shrinking problems.
I think the manufacturers purposely stretch the trim, to save on cost. If stretched, even with screws in the ends, failure is only a matter of time.
Jerry
rjsurfer
Think about getting the trim in black, never have to worry about it picking up mildew or getting dirty and looks sharp too.
Ron W.
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
newman_fulltime
buy the thicker use a blowdryer to imstall it
Lynnmor
the_bear_II
Although I've never seen a post in any of the RV forums, I'm guessing you could use some sort of vinyl treatment product (Armorall ?) on the insert trim every 6 months or so to help prevent shrinkage.
Jim-Linda
Its gonna shrink over time. Most have a screw on each end of vinyl run to prevent said shrink.
Jim
