โJun-27-2018 09:27 AM
โJun-27-2018 05:51 PM
โJun-27-2018 04:35 PM
DutchmenSport wrote:
Don't know about alternatives, but I'll give you my experience with the "Hitch Grip." If I could do it all over again, I'd never spent my money on one. Here's why.
When the holes of the shaft of my hitch head is in line with the receiver holes on the truck, the handle of the hitch grip is too long. In other words, I can barely get the edge of the shaft in the receiver when I have to remove the Hitch Grip and shove it in the receiver the rest of the way as I've always done. Although nice and balanced for carrying, it's horribly awkward when trying to position it anywhere.
Next, I keep my hitch head inside my pass through on my TT. Well, my pass through door is simply not tall enough for me to place the hitch head with the Hitch Grip into that hole. I have to put it on the ground, remove the grip, and then lift the hitch head and put it in the hole, like I've always done.
Now, if I stored the hitch head inside the garage, on the floor, or something like that, then it might be easier to use the grip. But this works only when there's nothing obstructing lifting.
I usually have the rear of the truck only about 5 feet from my trailer pass through. Using the grip is a bigger pain in the arse moving it just a couple feet than simply picking it direct with your hands.
I keep my grip inside my trailer pass through. And when I need to carry the hitch head a distance, it's nice to carry it like a suit case. But those times are so very rare, as my hitch is either on the truck or in the pass through and no where else, it just doesn't help me a bit using one.
I can see if someone stored their hitches differently, using different hitches on different vehicles and had multiple hitches, moving them around all the time, this would be a nice item to have. But for the novice user like me, that moves his hitch head only 5 feet, it doesn't work.
โJun-27-2018 01:39 PM
โJun-27-2018 10:30 AM
โJun-27-2018 09:52 AM
