โDec-03-2013 01:22 PM
โDec-05-2013 08:17 AM
โDec-04-2013 04:20 PM
Francesca Knowles wrote:Not quite but what is going on under the shredder plate? Read my first post.
I think there's a difference between "pumping" and "flinging"...the cutting blades just go around so fast on an in-sink-er-ator that the stuff is thrown up/down the pipe.
:S Wait- did I just describe a centrifugal pump ?!?
โDec-04-2013 02:05 PM
โDec-04-2013 01:56 PM
โDec-04-2013 09:51 AM
RJsfishin wrote:
Quote:
And for the guy who said garbage disposals do not pump.. NOT TRUE, they do.
Not on 12 volts they don't !! :B
โDec-04-2013 08:03 AM
โDec-04-2013 05:55 AM
โDec-04-2013 05:22 AM
โDec-04-2013 03:20 AM
โDec-03-2013 07:29 PM
โDec-03-2013 07:03 PM
โDec-03-2013 05:59 PM
Francesca Knowles wrote:I think you would find that underneath the shredder table are vanes that act as vanes in a pump. They are a support for the shredder ring but also act as a quasi pump vane within the drain cavity of the disposal. At least every one I've dismantled has been like that. I would imagine they are built like that to afford evacuation of the drain chamber with enough pressure through the final drain opening.
Garbage disposals don't "pump"....
โDec-03-2013 05:18 PM
โDec-03-2013 01:52 PM
