โJul-20-2022 07:53 AM
โJul-21-2022 11:39 AM
rphail wrote:
Thanks for the ideas, I am sure that I drained it but can say I am equally as sure I turned it on without water since at first I had forgotten the bypass valves from winterizing. Seams odd that the lines themselves leak at connection to the tank after about 5 minutes of filling the tank...will try to post a small video or pic.
rphail wrote:
When I took it out this year to make the first trip I found I was not getting any hot water. I remembered the bypass valves were turned to avoid the hot water tank, I reset them and the tank began to fill.... then the blue and red connections going into the tank began to leak out water (approximately the time I suspect it filled up, took 5 minutes or more). What did I forget and or perhaps do wrong last time I winterized it?
โJul-21-2022 09:31 AM
โJul-21-2022 06:35 AM
USAFBILL wrote:
The electric element may be toast if the unit was turned on without water in the tank
โJul-21-2022 04:09 AM
โJul-20-2022 12:14 PM
โJul-20-2022 12:06 PM
โJul-20-2022 10:02 AM
โJul-20-2022 10:00 AM
