Feb-20-2022 03:32 AM
Feb-21-2022 03:10 PM
Feb-21-2022 12:38 PM
CA Traveler wrote:
Most likely problem is the solenoid as significant amps are involved and DC is prone to pitting the contacts.
Feb-21-2022 08:30 AM
ramsaymike wrote:
As it happens, I monitor and record battery voltages continuously. This is what I got on the last drive. On start, the chassis batteries go to (about) 14.2 and slowly drift down to 13.6 over the 90 minutes of driving. The house batteries are at 12.0 and slowing increase as solar builds in the morning. After 20 minute break, the chassis batteries go to 13.7 but soon settle at 13.2 where they stay. The house batteries continue to build and are at 13.2 at engine off. It appears that at this point the solenoid is activated. From this point on the voltages of both sets of batteries are the same and it is obvious that they are connected. It now appears that the solar charge controller is controlling the voltage as both sets now start increasing. It is difficult to see what is going on as solar is variable but both are held at around 13.6. At the end of the drive the solenoid is deactivated - can't be sure exactly when but before final switch off. Trying to understand what is going on.....maybe just faulty solenoid?
Feb-21-2022 06:05 AM
theoldwizard1 wrote:AND it's high DC amps that cause more solenoid pitting on the contacts which causes them to fail including intermittent failure.CA Traveler wrote:
X2 I'm not aware of any MH that doesn't charge both banks from the alternator. Most likely problem is the solenoid as significant amps are involved ...
This has been discussed MANY times. It is NOT just about amps, volts are an issue.
For about 20 years, auto manufacturers have been installing "smart charging" systems on vehicles, even motorhomes.
Feb-21-2022 03:15 AM
Feb-21-2022 02:30 AM
Feb-21-2022 12:32 AM
Feb-20-2022 07:29 AM
Feb-20-2022 07:28 AM
IAMICHABOD wrote:
When I had the same problem as yours when the engine was running it was not charging the house batteries,after some testing I noticed that the continuous duty solenoid would click but not lock in which is a loud clunk.
After replacing it the problem was solved.
Feb-20-2022 06:44 AM
Feb-20-2022 06:18 AM
Feb-20-2022 06:00 AM
Lwiddis wrote:I believe the OP has a Class C MH.
Here’s a pretty good explanation of why a TV alternator doesn’t do more than an 80% charge under the best circumstances. Repeatedly charging to only 80% isn’t wise. See…
https://askthervengineer.com/youre-not-actually-charging-your-rv-battery-with-your-tow-vehicle/
Feb-20-2022 05:54 AM
wolfe10 wrote:X2 I'm not aware of any MH that doesn't charge both banks from the alternator. Most likely problem is the solenoid as significant amps are involved and DC is prone to pitting the contacts. It could be the connections which should all be clean and making good contact. It could also be the setup that activates the solenoid coil.Lwiddis wrote:
Without extra equipment the alternator won’t do a good job of charging your house batteries. Upgrade your solar system to charge them.
Sorry, I have to disagree.
While solar is a worthwhile upgrade for those who spend time "off the grid", the alternator SHOULD charge both battery banks.
To the OP: You need to troubleshoot your charging system. Do you have a diode-based battery isolator or a solenoid-based battery isolator?
Feb-20-2022 05:52 AM
