โAug-17-2020 04:40 PM
โAug-18-2020 08:41 PM
โAug-18-2020 08:37 PM
โAug-18-2020 03:26 PM
โAug-18-2020 11:14 AM
ramsaymike wrote:
I have a 2007 Coachmen Concord DS275 and discovered that the only way to charge the chassis batteries is by the alternator. Shore power charges house batteries only. This is a real issue for me as the engine cracking speed is critical in starting the 6L Ford diesel. I also have a solar system but it too is house only. I would like to be able to use the solar charging as needed to keep the chassis batteries fully charged. The battery interconnect solenoid would seem to be what I need to use but when I activate it (apply 12v) the headlights turn on which greatly reduces the charging efficiency. Any ideas appreciated.
โAug-18-2020 11:01 AM
โAug-18-2020 09:30 AM
โAug-18-2020 06:38 AM
โAug-18-2020 06:10 AM
โAug-18-2020 04:36 AM
โAug-18-2020 03:35 AM
โAug-17-2020 09:57 PM
โAug-17-2020 06:17 PM
BFL13 wrote:
ISTR reading on here that there is a trick to the trickle start?
It only works when one set of batts is higher voltage or some such?
BFL13 wrote:
Says here battery disconnect must be "on" (meaning "closed"? who knows???
โAug-17-2020 05:38 PM
โAug-17-2020 05:29 PM
โAug-17-2020 05:20 PM
