How do I hook a 3 pin connector to a 4 pin?
calstar
First post here! I recently purchased a small camper and the runnig lihgts(I assume thats what it is) have a 3 pin connecter, can I just plug it into the 4 pin splitter I have or do I need an adaptor?
Here it is:
thanks, Brian
17 REPLIES 17
calstar
.Get an adapter is my suggestion
You should convert the trailer to a standard four wire.
I have been unable to locate an adaptor, google searched but no luck. Don't have a clue on how to convert the camper to four wire, I'll search the net and see what I can find.
thanks, Brian
enblethen
Three wire as shown would normally have turn signals and brake lights but no taillights.
I would start by using a small jumper wire to see what functions are working on the trailer. Connect jumper to a good battery, use jumper cables to attach battery ground to rig. Then connect positive jumper lead to yellow and then green to see what actually works.
Follow black wire to see if it operates a function or is the ground.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cekkk
Don't know if it would work, but it's not a very sanitary solution. Get an adapter is my suggestion.
'11 Eagle 320RLDS '02 Ford F350 DRW 7.3 PSD
"The world will not be destroyed by those who do evil, but by those who watch and do nothing" - Albert Einstein."
