How long will my honda 2000 run on a gallon of gas
Carvin_Marvin
Just curious how many run hours on a gallon of gas. Currently at 7000' using econo mode to run the battery charger can I expect? It is a 3 stage charger.
10 REPLIES 10
dieseltruckdriv
I get anywhere from 10 to 15 hours on mine. That is at a bit under 4000'. I have a PD9260, but we are pretty easy on our battery usage, and the water heater and fridge are on propane.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
MEXICOWANDERER
An AC kWh meter would be useful.
rjf7g
I rigged up a 5 gallon marine tank. In the winter, I can run my fridge, a small space heater, watch a little TV, the microwave (with the heater off) and keep all of my electronics charged for an entire weekend on the 6 gallons of gas.
1999 American Cruiser Class B
2006 Palomino Puma 27FQ Bunkhouse
2007 Gulfstream Innsbruck 36FRS Park Trailer
ktmrfs
somewhere between the min and max runtime that honda spec's.
If your charging a big bank with 60A, about the most you can reliably get out of the honda for VA, you'll be running near 1600VA, the honda max continous power. If your running a lower amp charger it will run longer.
eco mode will adjust the output power to whatever the charger needs.
2011 Keystone Outback 295RE
RoyB
I usually get 6-7 hours a tank running my 2KW EU2000i Honda.
When camping off the power grid I run my 2KW generator every morning when allowed to power up my PD9260C Converter/charger unit to recharge my 50% depleted battery bank. This takes around three hours of generator run time to get them back up to their 90% charge state....
Then I am good to go for the next day/night run off my batteries...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
horizon36
It will run until it runs out of gas. ๐Ÿ™‚
Live Long and Prosper.
Home is where we park it.
FT since August 2010
'02 Itasca Horizon 36LD
'02 Jeep GC toad
Dakota98
And.......
Here's how Honda specs it > > Runs 4 to 9.6 hours on one gallon.
I would assume 4 = Full Load & 9.6 = Eco & both probably at Sea level.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
n7bsn
In Eco mode I get about 8 hours for a tank
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
Huntindog
mine have done from 8 to 15 hours in econ mode. As Mex said there are a lot of variables.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
MEXICOWANDERER
You're going to have to take all provided answers with a large grain of salt. Usage will fall within a wide window due to variables. Lbs of fuel per horsepower per hour is the formula.
