โJul-28-2015 07:13 PM
โJul-28-2015 07:59 PM
โJul-28-2015 07:32 PM
BFL13 wrote:cj7365 wrote:
I have 3 ea, 55 watt, 3.5 amp solar panels, what is the best way to connect these together. What gauge wire do I need.
I would like to use connectors that I can take apart, this will NOT be a fixed system on the roof.
I do have a controller.
It works better for amps to the controller if you feed each panel's wires to a common point (which could be the controller itself) instead of connecting panel to panel and then run wires from the last panel to the controller. Not a huge amount, but it does make a difference.
MC4s make a good quick connect, but you need long enough finger-nails to squeeze them apart. Wire nuts work, but can get frazzled after a few times. Anderson makes some other types.
โJul-28-2015 07:29 PM
โJul-28-2015 07:24 PM
